Hopper 3 with Hopper XIP813
RadioChuck
14
2
Phoenix, AZ
I currently have the Hopper 3 and will be adding an original (XIP813) Hopper to my setup. The question is... will the older XIP813 work with the dish (LNBF) that was installed with the Hopper 3? I'd like to use the two units side-by-side. The XIP813 is a beta unit and I'd like to be able to switch back and forth between it and my paid-for (and much more capable) Hopper 3.
Thanks!
I'm not even sure Dish will activate an H/HWS on the same account as an H3. But as said, you'll need a second Dish, or maybe combo of switches once the DPH42 is released.
Reactions: RadioChuck
Thanks!
A 'beta unit'? May we ask for further details?
The Hopper 3 uses a hybrid lnb. Also, there is most likely a solo hub installed. Easiest just to have separate dish for original Hopper and not try to integrate into existing system.
I'm thinking that's going to be the way to go. I know that the cable that comes from the dish is a straight run. I don't see any other electronics in the line. Regardless tho, I don't mind the additional dish. Just means they're going to have to roll a tech out to do it. I recently moved here and my ladder and a lot of my tools are still at the other house, out of state. Thanks.
I also believe that Dish currently will NOT authorize a mixed H3/XiP813 on a single account. That may change by January, but I doubt it. However, Beta units may be an exception, if you are still in the Beta program. If not still in the Beta program (and I would think the good people and the God at Beta would help you and answer this question for you), it seems you lose all your special status and are cast down among the mere mortals on this planet. I presume Dish has no interest in having you return your 1st gen Hopper Beta as they just don't care about those anymore and let you keep it, but mixing it with a Hopper3 on one account could still be NO GO. Confirm Dish will allow what you want before you waste your time. The best of luck. The computer system CSR's use at Dish may not even allow them to do it, perhaps not even DIRT can get the computer to do it, with exceptions for those at Beta Testing and a few other staff who have authorization for like celebrities and employees. Let us know if they make it work for you. If they do, they will probably not want you to tell us.
Total Newbie to Dish needing advice
Cast from Edge to Hopper?
