How do I "save" the ota channels I want in my guide on Hopper 3?
  • WELCOME TO THE NEW SERVER!
brownover
655
42
north carolina
I scan the ota channels. I check the channels I want to be in my guide. But no matter what I do, all the channels show up in the guide. When I go back to the antenna setup, it shows no channels checked and no signal, however all the channels are in the guide and I am receiving them.
This function/feature has been broken off/on. It was worst when there was actually a "Save" button, but it did nothing. Later, they removed that button and it simply auto-saves the current list when you leave that menu/screen.
I think your description of what you're doing is incorrect or you're doing it wrong. It includes all of the channels it finds. You only SELECT channels that you want to remove. You select them, then hit the button "Delete" (??) on the right-hand side.
Thanks Hall. I am doing it wrong because I am selecting the channels I want to see. On the directv am21, you select the channels you want to see. Since there are no instructions, I decided it must work the same way. Thanks again.
Reactions: Hall
