I had been looking at getting a C-Band dish for a little while, and on Friday, fellow forum member and friend Dfecarter told me that he had spotted one, and the location was about a half a mile from my house! I had driven by it several time and somehow had missed it. The dish had pine needles and leaves piled up in the bottom part, so it was likely that it was not in use. So yesterday morning I went and knocked on the door, and asked if they were interested in getting rid of it. This was my lucky day, the guy was very nice and was happy to get rid of it, on the condition that I also remove the post. Fair enough... less that 2 hours later I was back with a ladder and some tools and got started.
The dish is a Winegard 10'. It has a Polarotor with a Norsat C-Band LNB. No Ku. The actuator is a 24" ball screw Thomson-Saginaw.
I was also able to salvage about 100 feet of ribbon cable (2 coax, actuator cable and servo cable), with a bit of frayed insulation in one spot, thankfully not on the coax side
Everything is in decent condition, considering it's about 25 years old. The housing of the actuator is a bit rusted but the motor works - I have not tested the sensor yet. The Polarotor has some corrosion and peeling paint. But I might end up using my Titanium C1W-PLL instead anyway.
However, one mesh panel had gotten in a struggle with a pine branch and as usual, the branch won... It's not torn, but it definitely took a beating. Unfortunately on that dish the panels are probably inserted before the outer rim is welded, as it's in a channel on 3 sides (2 ribs and the outer rim) - see attached pictures.
What would you suggest? it seems that at a minimum I need to be able to take the panel out and flatten then part that got damaged and put it back in
I'm not sure of the exact model of the dish... From what i have found by looking at pictures it could be a Pinnacle or a Quadstar. If anyone can regognise it from the pictures and point me to a manual, that would be awesome. I looked at the Winegard Quadstar 7.5' manual posted in the forum, and it looks very similar, other than the size. I just need a bit of guidance on making sure i'm reassembling it correctly.
I'm open to all comments and suggestions from those of you who have done BUD rescue before...
Thanks again Dfecarter for the help in finding this dish!
