In the settings menu for the remote control device setting the DVD is set with a device. How can this device be deleted so it will say None?
I don't see a way to do that, Charles. You can change it to something else or put in a code that doesn't work for the device...In the settings menu for the remote control device setting the DVD is set with a device. How can this device be deleted so it will say None?
Thanks, that is what I discovered. Wish there was a way to return a remote to default settings. Probably classified information.I don't see a way to do that, Charles. You can change it to something else or put in a code that doesn't work for the device...
Does that happen when you set it at one time? On my H3, I've never touched that setting and it says "none" right now. As I recall, these remotes have occasionally done their own "software updates" - I wonder if that returns everything to defaults?I don't see a way to do that, Charles. You can change it to something else or put in a code that doesn't work for the device...
A DVD player is loaded in it now and I want it gone. No way to delete it I guess.Does that happen when you set it at one time? On my H3, I've never touched that setting and it says "none" right now. As I recall, these remotes have occasionally done their own "software updates" - I wonder if that returns everything to defaults?
I wonder what (if anything) would happen if the remote was "unpaired" and then "re-added"?A DVD player is loaded in it now and I want it gone. No way to delete it I guess.
but maybe the options aren't specific to the actual remote.I wonder what (if anything) would happen if the remote was "unpaired" and then "re-added"?
Tried that.I wonder what (if anything) would happen if the remote was "unpaired" and then "re-added"?
Weird - I just did too .... I added a Bose audio system under "auxiliary device" (it showed up when I was finished). Then I unpaired the remote, and after re-pairing, it shows "unknown, 0". This is with a 40.0 remote, if that makes any difference.Tried that.
Well you got a little further than I did. I will try unpairing again in the morning.Weird - I just did too .... I added a Bose audio system under "auxiliary device" (it showed up when I was finished). Then I unpaired the remote, and after re-pairing, it shows "unknown, 0". This is with a 40.0 remote, if that makes any difference.
just one of those "FWIW" kinda thingsWell you got a little further than I did. I will try unpairing again in the morning.
I would guess that there must be - strange though that it works for some but not for others.... actually, what am I saying?? We should be accustomed to thatTried manually unpairing, no luck. Unpaired and paired the remote to a Joey, no luck. I bet there is a secret procedure to set the remote back to default settings!![]()
Yep, I hear ya. Maybe it was me, but I just couldn't get the old setup to clear out.I would guess that there must be - strange though that it works for some but not for others.... actually, what am I saying?? We should be accustomed to that![]()
