Eastern arc vs Western arc
Interesting... is this due to lower signal levels, or ??
Also, is there a list somewhere which states what kind of signal levels one should be getting in their area? It seems Dish has signal levels in the 50's and 60's where AT&T you want all 90's and perhaps 80's on some.
Not entirely sure I understand why this would be the case. Where I live the EA birds are higher in the sky, so I would assume that means less atmosphere for the signal to traverse and therefore a stronger signal. As you move to the west, I guess that would change to eventually favor the WA birds, but I see people from the northeast US complaining, so I don't know.
Dish and Direct show optimal signal strengths differently. The attached screenshot shows ideal signals for EA
Reactions: Riverpilot
Well, I did some looking at these maps:
https://www.satelliteguys.us/thelist/database/Subscription/images/E16_Conus.jpg <- 61.5
https://www.satelliteguys.us/thelist/database/Subscription/images/NIMIQ5_72.jpg <- 72.7
https://www.satelliteguys.us/thelist/database/Subscription/images/Quetzsat1_Conus.jpg <- 77
and I am definitely within or very close to being in the white line (whatever that denotes), so perhaps I am just getting that much better signal than the folks to the north of me.
Not entirely sure how those compare to the WA birds though as there are no white lines on their maps:
https://www.satelliteguys.us/thelist/database/Subscription/images/E11_CONUS.jpg <- 110
https://www.satelliteguys.us/thelist/database/Subscription/images/E14_CONUS.jpg <- 119
https://www.satelliteguys.us/thelist/database/Subscription/images/CIEL2_CONUS.jpg <- 129
From my location here are the elevations of the Dish satellites:
61.5 - 32 deg.
72.7 - 40 deg
110 - 50 deg
119 - 46 deg
129 - 41.4 deg
So even 129 which I was able to get a signal meter strength in the mid to upper 60's is higher in the sky than 72.7 and especially higher than 61.5.
I rarely had drop outs when on WA, but EA, a heavy cloud even with no rain can drop my reception.
My signal strength on 72 is about 45, 61.5 is 51.
Very interesting. Thanks much for all the information. Considering AT&T is approximately 41 for me, the EA on Dish would be approximately 39 and WA would be 33.
61.5 - 32 deg.
72.7 - 40 deg
110 - 50 deg
119 - 46 deg
129 - 41.4 deg
Where are you located? EA is like that for me, just wondering if near the same area.
Edit:
Just checked and both EA and WA elevations are in the 30's
Probably Tampa8 will come in here any minute and claim WA is better (from FL?) than EA. But here in northern VA, when I was on mixed arc, the WA sats suffered far more dropouts, I think, simply because the elevation angle was so low that there was a greater probability of storms getting in the way.
Now, my Bradford pear is growing into the way. :(
WA is much better for rain fade in Tampa without question. DISH even changed the official ARC for Tampa years ago to WA from EA. Otherwise either ARC works fine. WA is better for rain fade in Ct too for me but not as a dramatic difference.
I'm in FL too and switched from WA (625) to EA (722), and I can say that my dropouts were less frequent on WA.
Reactions: Tampa8
Here in the geographic center of the continental US, I tend to get significant rain fade on EA vs WA, *except* on my native spotbeam, where signal strengths are 20% higher than CONUS
Reactions: Tampa8
Along with anyone else who wants to answer this question, when your picture drops out, is it like AT&T where it's for 10-15 minutes, unless it's one of those train storms where one thunderstorm after another comes pouring through?
So maybe a few minutes in difference between WA and EA, or are you talking a lot longer?
I guess which direction storms rolls through in a particular area will make the biggest difference.
I have DirecTV now and I would say it is about the same as the Dish EA was before it, at least where I live.
I'm on EA and all it takes is a cloudy sky. There doesn't even have to be rain in the forecast. I already had dish re align my dish and that did absolutely nothing. It was only 5 degrees off and it's still just as bad as before.
Well I have the advantage, or disadvantage, depending how you look at it, to use both Arcs depending where in the country I am based upon where the HD Locals are. I don't find either one drops more than the other when there is rain. I think on the WA, the rain disturbance can be farther away (no rain here).
I use a DPP 1000.2 with Hybrid LNBF heads.
Reactions: ncted
Doesn't 5 degrees seem like a lot?
EchoStar XXIV/JUPITER 3
Sanity check and advice for new install
