I'm sure he meant 5 points on the scale...Doesn't 5 degrees seem like a lot?
I've had dish since February and am furious with them because I can only get good signal a quarter of the year on the default install. On the opposite side of the state WA is default. No wonder they lose so many customers. At least PQ is good.
Once you have your OTA adapter, call Dish and speak to the Loyalty Team. Explain to them that signal quality hasn't been right since the beginning. Tell them you believe you need western arc and that the service is useless to you and you'll have to cancel if they can't help. I'll be you dimes to dollars they'll come out and replace it no charge.
WA (625) is SD broadcasting, EA (722) is HD broadcasting and requires more digital information so it does fade before the SD signal.I'm in FL too and switched from WA (625) to EA (722), and I can say that my dropouts were less frequent on WA.
5 Degrees would lose the signal. Sounds like a warped dish, what happened he isn't telling us about.No. I measured it myself before they came. It was off by 5 degrees which is a bit but the signal didn't get any better.
I thought the same! I've decided to not pay any attention to this poster because he often talks out of left field....5 Degrees would lose the signal. Sounds like a warped dish, what happened he isn't telling us about.
