Signal Strength For Phoenix
  • WELCOME TO THE NEW SERVER!
nicemann
61
42
Phoenix
I had a little trouble with the install and wanted to make sure the installer actually set my dish up correctly. Was wondering if anyone could tell me if these are good signals for Phoenix on a clear day.
119 - 40 Signal Strength
110 - 67 Signal Strength
129 - 19 Signal Strength
Thanks for the information.
129 seems way low. Just for Jeepers, go to transponder 7 on 129 and see what the signal is there.
That is quite good. That transponder is a spot beam that has a few of your local HD channels. Next, try transponder 24. It is Conus and has a bunch of regular HD channels.
129 - transponder 21 is only 20 signal strength
You're just all over the place. I would replace the LNB and realign the antenna and go from there.
I wish Dish would fix the signal strength meter, they used to be able to reliably report signal strength.
