Is the TV2 from the VIP722 decrypted so you can use a USBTV Tuner stick ? (ATSC/OTA one ?)
ThePizzaPizza
3
Texas
So I'm thinking about running the coax to my computer to watch instead of having to purchase another TV. Since the output is only 480p, and I have a 1440x900 monitor, I figured I'd save money instead of buying a cheap small 720p TV.
But would this work ? I know it comes over Channel 60 on TVs.
Yes that will work, as long as its support Analog broadcasts it will work. Just be aware it will be SD only. :)
I was thinking something simple like this:
DIAMOND ATI Theater HD 750 USB TVW750USB USB 2.0 Interface
on newegg. (Can't post the link for some reason) . Says: NTSC Analog TV Support .
edit: the
[h=1]KWorld Hybrid TV Stick UB445-U2 USB 2.0 Interface[/h]
looks a little bit better though.
After I believe it's 5 posts, you will be able to post links.
Welcome to SatelliteGuys. Stick around and join the fun.
Reactions: comfortably_numb
Yes it does work. I used a Hauppauge 850 usb tuner stick and watched on a 21" crt monitor when the other tv connected to TV2 (via composite) was being used for gaming. It looked like crap though and I quit doing it. The tuner was better served for ota broadcasts.
Hello everyone it's been some time since I have been On but I get the fc c up date on the atsc 3 and the low vhf ct has low vhf and the atsc 3 and the channel master box 70001 and it does all and the new box for $800dollars but only one person that makes a hi low vhf/uhf that will definitely work well with a channel master amp well every one good luck p.s. and uhf fc c found out something that would not work SO you know what that means more channels!!!!!!
I understand the bolded.
Translation: He's saying he's been updated on ATSC 3.0 by the FCC, and claims that Connecticut (next state over from where he lives) has a low VHF station and ATSC 3.0 already running. He also says/claims the Channel Master 70001 (I think he means the 7001, which is a really old converter) priced at $800 can do ATSC 3.0 (Nope, sorry it doesn't). He's also added something about high/low VHF and UHF combined antennas that only one place still sells will work with a Channel Master (pre?) amplifier.
He's on multiple sites, and believes he's an expert in OTA tv. Nearly incomprehensible 98% of the time, however if you read enough of his posts you can get the gist of it all.
I thought there were only two ATSC 3.0 transmissions currently "on"... Cleveland (where they did a lot of testing) and WRAL in Raleigh. Connecticut has one?
I doubt it. Nascar Ken repeats completely false info all the time, on every site. Though I think he really believes it himself. I said I can pretty much read/understand his posts after several years, I never said I yet understand him/where he's coming from.
For what it's worth, I do believe he truly thinks he's being helpful.
Wow, well done!
Old Hopper UI
VIP receiver installation
