forced download
sstv
40
2
Hi All
I have no luck forcing a HS17 download. Whats the trick?
SSTV
The last I knew you have to be on a list to get a forced download unless it is a national release. In that case, it's only available within a certain time frame.
Reactions: Jimbo
Red button reset. When white light comes on hold down add client button until white light is flashing.
Download is in progress when white light is flashing.
Reactions: whitewolf8214
After red button reset when white light comes on hold down add client button while white light is flashing and what is the hold down add client button? Thanks for help appreciate the help
Suggest before doing a forced down load on the HS-17 - First remove the internet Connection -then start the download*that's) the missing step - If you are wireless -Remove the settings before reboot - If wire-Unplug the lan cable
Add client button is the button on top
It will actually attempt the download via internet if you have a wired connection
I didn't hold the button down, just a poke. I will give your method a try
SSTV
SSTV
Well I tried holding the button down until solid white, did not work. now what?
WHILE solid white. Once it turns white THEN hold button down UNTIL it starts blinking.
After reset, the top light turns white and you hit and hold the button until the white light starts blinking then release the button. I think we are both saying the same thing.
SSTV
Hi All
I gave it one last chance and the new software downloaded. I got "1001".
SSTV
I was able to d/l 1001 to my hr44 this morning as well .... then off to work so I have no idea if anything has been changed.
