Pixelation
linus259
57
9
I have a system consisting of an HR-44, HR-24 and three H-25's on a SWM 16 switch. The last few days I have had pixelation and blocking with sound drop out on most channels for a few seconds at a time. This happens on all of my receivers and all channels EXCEPT my local channels out of Paducah KY. I did a system test with no problems noted and a signal test. All of my signal levels are above 90 with most in the upper 90's except on the (s) sats which is normal.. I rebooted everything and unplugged the power inserter. Nothing has helped so far. What would cause this problem on most channels except local channels with good signal levels? The pixelation is not continuous and has a good picture after a few seconds but starts again after a few seconds.
Could be a wonky lnb, swm switch, or bad cable. One of the installers will chime in soon and give you a better idea.
I went ahead and had a Directv Tech come out this afternoon. He replaced the LNB with a new reverse band one and got rid of the SWM 16. They wanted $99 for the call but they signed me up for a service plan for $7.95 and said I could cancel after a month. I had always heard there was a penalty but she said they changed that policy. Even if I have to pay the $10 penalty it's still cheaper to do that.
Reactions: whitewolf8214
No penalty as long as you keep it a month.
AT&T & DIRECTV NOW Are Merging Logins
Skipped due to programming update?!
