Setting up SWM 3 LNB with HR22-100 problems
are you using the dithering technique to find the center of the 101 beam?
You need to forget about 99/103 for the moment. Pick one of the 101 TPs that is low (but not a spotbeam), say TP15. Dither on that TP only. If you can't get it into the 90s. then I would say you have a bad dish (or receiver, but less likely)
Is it possible that he's looking at the wrong Sat ? 119? maybe.
Regardless of which satellite he is pointing to, he should be able to get higher than 75 for a signal strength.
Okay .. I'll give that a try .. I know the receiver is good .. I use it at my home. This dish is at my cottage that I'm trying to get set up.
If your trying to point at the 101 and you actually have the 119, you'll never get the 101 numbers where you need them.
Here is what I get right now ....
satellite-1-jpg.131951
I'm thinking a bent dish then. They can look good but actually be bent.
