C & Ku lnbf
Ron Kolasa
18
6
Sardis Tn
First off thanks for the info on my earlier post, I wasn't aware of the fact that I was between two satellites and you guys nailed it.Now I'm receiving 103w with good results.
I do have a question though, I have a titanium C & Ku Lnbf and when I fine tune the skew on Ku I loose a couple of channels on C band. Would it be better if I use a C Lnbf on the 7' dish and Ku
on my 30" dish or stick with the combo c&ku. Also does it matter if the diseqc 4 switch is on the dish or inside behind the receiver
Thanks for the reply, that's was kind of the route I was leaning towards, do you have any recommendations on a C Lnbf or is the titanium as good as anything else.
Reactions: Titanium
I have another quick question On my titanium C&Ku Lnbf can I just use the C band side of it and on my other dish use my geo sat pro SL1PLL for Ku band. Thanks
I have a diseqc switch I will split them and put some diaelectric grease in the open Ku port on my titanium. Thanks for the support
Could I get a bit more locked in?
Post Your Favorite FTA Test Pattern
