Thanks Ypsiguy!Nimiq5 (72.7W) is definitely the weaker of the two. In Michigan, I have a 1 meter dish pointing at it. That said, in NC you should be seeing a better signal than 30-40. Should be up around 50, from my experience. You may need a dish tweak.
Thanks Ypsiguy!
I live in eastern NC so the 72 satellite is almost straight above me. Thanks for your input. Atweaking I will go!As a comparison, I'm currently in upstate NY using a portable tripod mounted dish that I didn't spend a lot of time dialing in. I'm seeing a 53 on 72 TP21.
Atweaking I will go!No problem. I should add I usually see around 50 for most transponders on Nimiq5 on my "official" Dish HD system. That is the dual LNBF system that was installed by Dish for 61.5/72.7W.
I usually see signal from Nimiq5 in the high 50's and low to mid 60's on the dual dish system I personally installed.
Yep, tweaking does seem to be in order... The 72 sat is still over the equator though, so not quite straight above you. More like a ~48 degree elevation.I live in eastern NC so the 72 satellite is almost straight above me. Thanks for your input. Atweaking I will go!
Yes , you are right. And I think elevation is my problem. Just a little off.Yep, tweaking does seem to be in order... The 72 sat is still over the equator though, so not quite straight above you. More like a ~48 degree elevation.![]()
Actually what I meant was compared to NY it is almost over me. Again, thank you.Yep, tweaking does seem to be in order... The 72 sat is still over the equator though, so not quite straight above you. More like a ~48 degree elevation.![]()
Tweaking did not help. Adjusted azimuth, elevation, skew and checked for level. Everything like it is supposed to be. It is an old dish 1000, could the size be causing the weak 72 signal?Actually what I meant was compared to NY it is almost over me. Again, thank you.
Can you take a picture of the backing structure?Tweaking did not help. Adjusted azimuth, elevation, skew and checked for level. Everything like it is supposed to be. It is an old dish 1000, could the size be causing the weak 72 signal?
For someone incapable of tweeking my own dish, will DISH come out to tweek it for me?
Thanks HipKat, I got Dish to send a tech out.Can you take a picture of the backing structure?
