Resurrecting a roof-mount dish project
comfortably_numb
23,669
39,789
New Mexico
Now that the weather has finally cooled down and I have some extra time, I'd like to try and mount a 76cm or 90cm dish on the roof for either 113 or 125.
There is a mount up there where a Wild Blue dish was. There are also 2 smaller attachments for support arms. At my location support arms are important as it can get extremely windy here.
I would prefer not to have to drill and seal any additional holes on the roof. The issue is that the mount for the Wild Blue dish appears to be for a larger than average pole. Most FTA dishes are on smaller poles.
Any ideas on how I can mount a 76" or 90" dish using the former Wild Blue mount and support arm attachments?
I've been looking around for Wild Blue dishes I might be able to take the mast and support arms from but they are so few and far between anymore.
Make an adapter. Slip a smaller diameter (1 5/8" OD) post inside the larger Wild Blue (2" OD) mount, drill three right angle holes and use through-bolts to prevent the inserted post from rocking.
Thanks. What do you recommend as far as the support arms?
Sorry, I understood the Wild Blue mount was already installed. If so, less damage to simply add legs with pitch pads underneath, rather than remove an installed mount and likely damage the roofing with removal.
If not already mounted on roof, install on eave overhang, not over living space and use pitch pads under the mounting penetrations. Preferably mount on the fascia or wall mount if structurally sound or appropriate.
Alternatively, the Wild Blue mount and arms could also be affixed to a peak NPRM tray frame. Easy to construct out of angle iron, concrete blocks and a neoprene pad underneath.
Aim at 125W. 113W only has Reuters, unless you understand Dutch and want BVN America.
I have similar scenario with a Shaw dish not being used on a nice roof mount. But FTA on the roof is against my policy. I always want to change to different satellites.
Sent from my SM-G950W using the SatelliteGuys app!
I noted that wallmart's now selling FTA satellite receiver!
need help identifying pre-slimline dishes
