I read on an old thread that simultaneous output to HDMI and composite. I just added a composite cable to H3 but TV getting no input on composite. Is there a change from the 2016 thread or is there something I'm missing?
) If the HDMI cable is in 4K, the composite may get no signal.Just to be clear...are we talking the SD composite output, or the HD component output?
You said composite because the OP said composite.
Sorry, meant componentArgh! I can't believe I typed "composite" so many times when I meant "component".![]()
Did you change your TV input to component?HDMI works. Component doesn't even with hdmi unplugged.
Of course. Even hooked up an old vcr and it worked.Did you change your TV input to component?
An old VCR? Does that have a component output or a composite output? They are different and will have different input settings on the TV.Of course. Even hooked up an old vcr and it worked.
I did that too.You still aren't doing the diagnostic that I suggested above in post #2. Instead, you unplugged the HDMI cable! That's the opposite of what I asked.
Plug HDMI in and get the H3 showing video (not 4K) on that TV. Then plug in the component, preferably to another TV, and then what do you see?
I did that too.
