- Nov 29, 2003
- 17,635
- 23,120
What is wrong with that?While it's great having MeTV back, it's also why I'm not particularly thrilled it's as a streaming feed...HD or NOT.
I have it here in Kentucky.I am wondering if I am seeing it because I am a beta tester? I only looked as the other person posted they have it now, and I had it too. I don't know if the other user is a member of the Beta Program as well.
If its not generally available yet then I do apologize. But it does appear to be coming soon, which makes me happy as now I can record Svengoolie with guide data. My local TV has no guide data on my Hopper.
The same reason I didn't like it on FrndlyTV...having the broadcast feed altered with "substitute" programming, that doesn't seem to be as good as what should actually be there...What is wrong with that?
What programming does the national/streaming feed replace?The same reason I didn't like it on FrndlyTV...having the broadcast feed altered with "substitute" programming, that doesn't seem to be as good as what should actually be there...
It was not there last week. I did look.
SO I am very happy about this... and again I say get MeTV Toons now too!![]()
I checked as far as I could and the streaming and ota feeds are the same in the Birmingham DMA.What programming does the national/streaming feed replace?
The programming shows are the same, it is the episodes that may be substituted. Again, I noticed this with a Matlock episode yesterday. Both the steaming and OTA feeds were showing Matlock, but the episodes were different between the OTA and streaming feeds.I checked as far as I could and the streaming and ota feeds are the same in the Birmingham DMA.
I was able to set a timer for Svengoolie by search for Svengoolie.Streaming guide only goes a couple of days out. Then check back later if you go three days. Noticed this at my buddy's house when I tried to set up a timer for Saturday night shows on Metv.
That would be correct just like when DISH had MeTV beforeSomeone in another forum is saying they do not get see this channel. Is it possible that this is not delivered if a subscriber gets their local MeTV through DISH?
The problem with streaming feeds is that it defeats whole purpose of the Hopper 3 with all of its sat tuners. Recording streaming channels is very limited because you can only record 2 or 3 streams simultaneously and is dependent on your internet bandwidth. Also, not everyone has unlimited internet service.What is wrong with that?
Thank you for the clarificationThe following DMAs will not have channel 247:
- Anchorage
- Atlanta
- Buffalo
- Chicago
- Denver
- Duluth-Superior
- Green Bay-Appleton
- Great Falls
- Honolulu
- Houston
- Jacksonville
- Lafayette, LA
- Lincoln & Hastings-Kearney
- Little Rock-Pine Bluff
- Los Angeles
- Macon
- Marquette
- Milwaukee
- Monroe-El Dorado
- Nashville
- New York
- Panama City
- Philadelphia
- Phoenix (Prescott)
- Rapid City
- Seattle-Tacoma
- St. Louis
- Tri-Cities, TN-VA
