High Gain UHF TV Antenna ideas
k4otl
163
219
Johnson City, TN
So... my own OTA situation at my house is pretty great, I'm ~25 miles from the local transmitters, and get ~40 channels. I like my free TV and run split UHF/VHF antennas, mainly because I have a 13' monster from the 80s that works fantastic on VHF, it's on a rotor I use to pick up out-of-market TV and FM stations.
At my Dad's it's a different story: He is actually closer (by mileage) to the transmitters than I am, but there's a 3000' ASL mountain in the way. He can fairly reliably get 3 stations (2 very high power UHF and a VHF) but there's 1 UHF that's not always reliable, and 1 UHF that's just out of reach it seems (it'll flash on scan but never has locked in). My father is not keen on antennas all over the place (I am :) ), as long as he can't readily see them he's fine with it. Right now he has a small high-VHF beam that picks up the VHF station fine, and a Range Experts "Insane Gain UHF only" UHF ONLY VERS INSANE GAIN Outdoor HD TV Antenna
antenna that I put in the attic. For VHF if I turn that antenna 10-20 degrees toward the south I pick up WLOS from Asheville, but then I lose the local VHF :( . This (back to UHF) antenna (and it's attic location) greatly helped the reliability of the UHF stations, but I'm looking for more if possible. Tbh my father doesn't watch much OTA other than news occasionally, I tend to want to watch COZI and Weigel channels when I'm visiting.
Does anyone have firsthand knowledge of the Channel Master CM4228HD versus the Range Experts antenna(s)? I thought about experimenting with the 4228HD in the attic.
I have an older version of the Channel master 8 bay antenna and it performs very well in my area. That having been said, if there is a literal mountain in the way you may or may not have success with it.
If you could go to https://www.rabbitears.info/searchmap.php and post the link to the report for your dad's address it would help us to give you better advice. That will give you an idea of exactly what you can receive under ideal situations.
It will even let you play with different heights to see at what level the antenna needs to be in some cases. For example, to get out of the "poor" signal range in my area I know from Rabbitears that my antenna has to be at least 22 feet high. Attics also hurt reception in most cases. You'd stand a much better chance outdoors, but the report will tell all.
https://www.rabbitears.info/s/2390735
So my Dads elev is ~2400', so not as insurmountable as initially made out to be. Note in the report that WJHL and WCYB tend to be very reliable, even with the small combo outdoor antennas (sidebar: WCYB was low-VHF till a few years ago, at that time I could pick it up with a split tail of coax onto a piece of HVAC duct grating, we never had problems with low-VHF). WEMT is generally reliable, WKPT is receivable >60% of the time, but is defnitely not as reliable. WAPK-CD is the one I'd like to receive, the report says it should be stronger than WKPT but it definitely isn't. WLOS is receivable but is a little too off axis and far away to pick it up along with WJHL :(
WLFG on UHF would be nice to have, but also too off-axis. If I get WLOS I can do w/o WLFG (GET TV!)
Not going to lie, that is a pretty bad reception report. Almost any setup is going to have issues from time to time under those conditions. If I were going to try that I honestly would look at something like this Televes 149884, DAT BOSS MIX LR Repack Ready! Antenna W/5G Filtered Pr from Televes myself, and I'd definitely get it up outdoors.
I honestly wouldn't waste any effort trying to get WLOS. They're supposed to move their transmitter from that location anyway, so if/when that happens they likely would be out of the picture.
Before I moved ten years ago, I used a CM-4228 and it was fantastic. I originally purchased it about 1997. Very heavy and made from steel. Made by Channel Master in North Carolina. That CM went bankrupt, after losing a contract to make Satellite Dishes about 2000.
I now have the new CM4228HD. I am very disappointed with it. And cannot recommend it. Two other CM antenna that I use and are happy with are the CM-2016 and CM-2018.
Reactions: navychop
Didn't know about WLOS moving, that stinks. Looked up new TX location, it's 2000' lower! I can get it from my house currently as well when I turn the rotor that way.
As far as reception, it's better than one would think looking at the report, and Holston Mtn is less than 15 miles away, but the dang mountain in the way doesn't help. 1 edge diffraction for sure. If it were my place I'd have it covered in antennas and Ku/C band dishes. I may sneak a Ku dish to supplement OTA.
Anybody have any experience with these antennas? Look like super high gain on UHF, would be narrow beamwidth: Xtreme Signal 70 Mile high-VHF/UHF Yagi Outdoor TV Antenna (HDB91X) | eBay
Yeah, I used them for years, until I replaced them with Televes 149884's. Which have built in preamps that also filter FM and 5g, AND are high VHF & UHF.
The HDB91x's have very high gain, are UHF only, BUT it's highest up around channel 50, which is no longer there. They are ok, but they are passive, so ok IF you don't need a preamp, or care about FM radio or 5G intrusion above channel 36.
Does anyone have actual experience with the Channel Master Pro-Model UHF/VHF TV Antenna? Modular design that you can add to in order to increase gain. $50 for the UHF piece and $50 for the VHF. I'm wondering if it's worth the money.
Thank you. Checked your link and notice they have a better range CM-2020 for $120.
Ranges published by manufacturers and/or sellers of TV antennas are mostly speculation and sales pitch.
The beam width is inversely proportional to the antennas range, the longer the range, the narrower the beam width.
This site (HDTVPrimer.com) is old (circa 2003) but it gives a good primer of what to look for.
At the time the Winegard PR-8800 8-Bay and the old AntennasDirect DB-8 8-Bay were the strongest in the current UHF spectrum.
If you are trying to get a specific UHF channel, the strongest antenna would be a yagi tuned to that channel, but that might preclude others if they aren't nearby in frequency.
All commercially sold antennas are compromises trying to get the full spectrum with one antenna.
Physics of RF reception have not changed.
You have my curiosity, what has been disappointing about it? Do you have super strong locals or trying to receive at great distance?
I'm mainly disappointed in the lack of VHF channels received. The CM-2016 does receive more in the same location. I live in a condo and want the smallest antenna that get all my locals. I'm in a "HOT SPOT" for both FM and 5G interference, so I use both CM-Filters. I receive about 50 channels OTA and at my low elevation below a lot of 900 ft. hills am happy.
Reactions: k4otl
Is the lady that helps with Dish problems still on the forums?
Silicondust launches Grand Slam MDU TV
