When the weather gets below 5 degrees, I lose the satellite signal. When it warms up to 10-15 degrees everything returns to normal. What could be the problem? LNB?
It's the LNB affected by the extreme cold. Same thing happens with extreme heatWhen the weather gets below 5 degrees, I lose the satellite signal. When it warms up to 10-15 degrees everything returns to normal. What could be the problem? LNB?
Could be the center wire in the cable shrinks back away from the connection in cold weather.It's the LNB affected by the extreme cold. Same thing happens with extreme heat
Not really, if the connection is tenuous extreme cold can shrink the center wire enough to pull it back from the connector. Make sure your stingers are adequate.That would be some incredible shrinkage.
I know of one stinger which definitely shrinks during extreme cold.Not really, if the connection is tenuous extreme cold can shrink the center wire enough to pull it back from the connector. Make sure your stingers are adequate.
I know of one stinger which definitely shrinks during extreme cold.![]()
Stay out of the pool!
I just posted the same thing and then deleted it because you beat me to it.
I live in Minnesota and I have the exact same issue on the satellite dish mounted up on my roof, but it has to get down to below zero. Once the temp falls below -10 or more, I lose signal. If you look at the signal strength screen, it will jump back and forth from 79 to 0, no in between. The LNB up on my roof is a Hybrid and feeds my Hopper 3 and 2 Joey 3s. I know it is not the Hopper 3 as I used to have a Wally connected to it and it did the same thing.When the weather gets below 5 degrees, I lose the satellite signal. When it warms up to 10-15 degrees everything returns to normal. What could be the problem? LNB?
Generally sat electronics work better in cold, not worse. These described issues of sudden unexplained loss in cold sound exactly like the postulated too-short coax center conductor- physical contraction of circuit elements. Possibly something in the LNBF could be contacting and breaking circuit.I live in Minnesota and I have the exact same issue on the satellite dish mounted up on my roof, but it has to get down to below zero. Once the temp falls below -10 or more, I lose signal. If you look at the signal strength screen, it will jump back and forth from 79 to 0, no in between. The LNB up on my roof is a Hybrid and feeds my Hopper 3 and 2 Joey 3s. I know it is not the Hopper 3 as I used to have a Wally connected to it and it did the same thing.
I have a second dish mounted on the side of my deck that has a DPP LNB and this feeds my Wally. It never loses signal even when the temp falls to -20 with wind chills to -40.
When dish first came out with the slim hybrid lnbs this was a big issue in the northern states. But they supposedly redesigned it to correct the issue. However it may be a good lnb and still happen regardless. But it doesn't hurt to call dish and see about getting the lnb changed out just to eliminate that as an issue.Generally sat electronics work better in cold, not worse. These described issues of sudden unexplained loss in cold sound exactly like the postulated too-short coax center conductor- physical contraction of circuit elements. Possibly something in the LNBF could be contacting and breaking circuit.
That's what she said.I prefer compression to crimping.
I used to strap Peltier coolers on a lnb to lower the temperature. The heat noise is a big deal for a very weak signal. I could effectively double the antenna size.Generally sat electronics work better in cold, not worse. These described issues of sudden unexplained loss in cold sound exactly like the postulated too-short coax center conductor- physical contraction of circuit elements. Possibly something in the LNBF could be contacting and breaking circuit.
I used radial-taper crimping, which could possibly be considered compressive as it leaves a seamless, tapered crimp that resists moisture intrusion if has o-ring.. Most others were using some kind of multi-part fitting with a plastic center. I don't even know what to call those. Compression?That's what she said.
