2 Diseq-c to 4x4 switch?
Earving
17
Can I connect two diseq-c to a 4x4 DTV switch to use the 22khz switch that had this switch? One diseq-c to 13v port and the other to 18v or how?
If not how can I connect two diseq-c without a 2x1 22khz switch and use the 4x4?
Another kind of diseq-c?
Thank's.
are you trying to hook up 2 dual LNB's?
if so, run both lines from one LNB to the 13v & 18v on the multiswitch and the opther lNB to the 13+22k & 18+22k sides
4 outputs and no diseqc switches needed :)
I want to hook up at least 6 satellites to the two diseq-c (4 in one) and (2 in the other) and the the two outputs of the two diseq-c's connected two a 22khz switch but I only have a 4X4 DTV switch, can I use this switch to be used as a 22khz on off, but this switch have the polarities separated.
you need a 22k switch unless you wanna get like 1/2 of satellites (either H or V)
You can't do it this way. You'll need 3 4x4 multiswitches hooked to 3 of the ports on a diseqc switch.
30'' round dish, how to get 97W and 95W at once?
New to fta...using old dish for fta?
