Please help with switch problem
altadata
43
Hi...
I want to connect a diseqC switch and a 22 khz switch.
I have LNB1 going to 22KHz input A and LNB2 going to 22 KHz input B
The 22 Khz output is then connected to a diseqc switch.
In the Coolsat 6000 menu for the 22Khz settings I have the choice On/Off.
I set On.
The problem is that I always see the LNB1 ( the one that is connected to 22KHz A ). The one that is connected to 22Khz input B is never selected.
TIA
I took the diseqC switch out and now the receiver is connected directly to the 22 Khz switch output.
So how am I supposed to use the 22 KHz switch in a simple setup ( receiver, 22KHz switch, 2 sats connected to the 22 KHz switch inputs ) ?
Thanks.
make sure both LNB's are standard and not Universal
to use the 22k switch it goes reciever----22k-----LNB's (one on each port)
In the setup on the reicever one is 22k on and one is 22k off
Is the 22KHz switch supposed not to work with circular LNBs?
I'm trying to have 119 ( Nasa TV ) and 110 ( GolTV ) by connecting
110 to inputA ( 0Khz ) and 119 is connected to inputB ( 22Khz ).
The output of the 22KHz switch goes to the receiver ( Coolsat 6000 ).
In my setup I have:
110
LNB Power ON
LNB Type Single
LNB Freq 11250
22 Khz OFF
DiseqC OFF
119
LNB Power ON
LNB Type Single
LNB Freq 11250
22 Khz ON
DiseqC OFF
The problem is that I'm always connected to 110 ( input A 0KHz ).
The switch seem to have been defective. I replaced with another one ( the same manufacturer DMC ) and this one switches fine.
Thanks.
StarChoice & ExpressVu w/Dish 500
Novice question
