Few questions about FTA, I have the VIP 622, what sort of antenna can I use to gey local HD channels I would love to cancel this HD package.and can i Still record to the DVR with it?
FTA and OTA are two separate entities. FTA = Free To Air and the 622 doesn't view these channels. OTA = Over The Air and are your local channels, the digital/HD versions of which can be incorporated into the 622 (there is no tuner for analog channels in the 622). The guide would be there, but if you do not subscribe to the local package there is no guide data. They can still be recorded by using manual timers. As Jimmy J. said, you should determine what antenna you will need.
Well DetFan, it depends on how many of them channels you want to get? From the bearing/dist number provided your probably near Garden City. If you just want the Detroit digitals (HD) then something like this will work good. http://www.solidsignal.com/prod_display.asp?main_cat=03&CAT=&PROD=SCM4221A. Put it a couple feet above the roof and aim it at Southfield, Royal Oak and your done. No preamp or rotor required. Even a good indoor uhf might work, http://www.solidsignal.com/prod_display.asp?main_cat=03&CAT=&PROD=ZHDTV1. Do you ever watch hockey night in Canada?? Want the Toledo HD's?? I see a Cleveland station on there but you can forget that.
Ah forgot to ask..
With this one work indoors or do i have to run it from ontop of hte house?
http://www.solidsignal.com/prod_display.asp?main_cat=03&CAT=&PROD=ZHDTV1, All im looking for is getting my main Locals in HD..
And Can I run this through my VIP 622?
If you have stations that are close, I would stay away from anything with an amp, the 211's and 622 start having multi-path issues. After having said that the radio shack antenna worked good above, it worked great on the TV tuner, but sucked on the Dish tuner with a close local, multi-path issues immediately. The only antenna I have been able to get to work reliably is the Zenith Silver Sensor, all my stations are within 35 miles. I have had no luck with any amplified antenna.
