I'm going to add a FTA receiver to my analog C/KU setup. Looking at this site shows using two splitters.
http://www.dmsiusa.com/add_a_receiver.htm
yes you would need 2 high frequecy splitters (up to 2200MHZ) to add a DVB box (FTA box) to an existing C/KU setup if you have an analog box or 4DTV already setup
no
The diseqc allows you to hook up to 4 LNB's or dishes to one reciever. The diseqc switch would allow you to switch between C-Band and KU Band (in your setup)
The splitters allow you to split the cable coming from the LNB to go to both recievers
The splitters can be found at most electronics stores like Radio Shack. Just make sure the frequency range goes up to 2200. The cheaper ones stop at 1000 which won't work (satellite runs between 950-1450)
Power pass is important to allow the receiver to send voltage to the LNB.
Only one port should pass power. If you can only find a splitter that passes to all ports, you can purchase DC blocks that will prevent the other receivers from sending voltage to the LNB.
Looks like that one is specifically designed for satellite use. Should work well.
The analog receiver probably won't be moving the dish through the coax... at least I've never heard of one that does, although a modern one might. Chances are your analog receiver is moving the dish using an actuator and ribbon cable. You might want to slave the analog receiver to your DVB digital receiver. That way, you won't have to use a splitter at all. Just use the loop through on the DVB receiver and connect that to the analog receiver input. You'll want to place a DC block between the analog receiver and the DVB receiver in this case.
we used to have cable digital cable and cable internet at an old apartment. When they guy came around to install it, he hooked several high frequency splitters, and actually gave us one or two extras, no charge. I'm currently using all mine, but if you know someone with cable, might not hurt to have them make a call to the cable guy?!?...![]()
