Local problems
If so try resetting you receiver,and maybe try satellite setup again and make sure you've enabled that satellite to pick up a signal.
It is a d-11 reciver I have + 88 to 100 on my 101 core programming satellite. I run my 72.5 satellite that has a + 77 on 18v in to flex one on my switch then set the d-11 to a round dish singal feed then auto detact.
I can only get cw . Am i doing this right.
I'll have to let someone else help you .I don't know much about the D-11. But from what I see you have a signal?
Are you only trying to get the 72.5 and nothing else? Try setting your dish to whatever type of dish feeds your multi-switch before the 72.5 is connected and running autodetect again.
Also, your dish may not be pointed exactly correct. You may be getting an "echo" from one of the sats on the dish.
Your CW may not come from 72.5, it may come from 101. What's your zip code?
