Channels Removed from PI package?
BabaLouie
313
30
Northern Rockies
Flipping through the channels today, I noticed that Starfish and Pentagon no longer show up in my electronic programming guide. Probably some others missing, too, but those two are channels I watched occasionally.
Bablouie
I assume you don't have a basic package with Dish and that's why you get the PI channels separate?
I don't have my box setup (its on vacation) so I can't check...I have DishFamily & locals and the PI pack :)
Switch test shows all is OK.
I still get all of the sub channels I had on all three sats (119, 110 and 61.5).
Only lost some of the PI channels--still getting some of them.
Do a signal level test on a couple transponders on 61.5..let it lock completely (on the signal) then do a check switch
I know it doesn't solve your problem, but I just checked and the channels you mentioned are still appearing for me.
Have you double-checked that the channels are not locked out? A while back I discovered that I had locked a channel and as a result thought I wasn't getting a channel in the PI pack.
Good luck!
Good luck!
The channels are not locked out. I will do what Juan suggested in his last post and see if that solves the problem.
Still no Pentagon and no Starfish. I did all the steps suggested. Strange deal...
Maybe it's an issue with my receiver? My 322 has been, at times, freezing up, etc..
BHM DMA online
When did this happen?
