Has anyone tried connecting their drive to a 2nd 622 yet?
Be very careful with that. They said on Tech Chat that it can ONLY be switched to a different receiver THREE times. After the third time, it locks to whatever receiver it is on.
Yes, confirmed and not that I know of.Can anyone confirm that the USB drive is not accessible from TV2? And if not, any info on if it eventually will be?
The Multimedia menu has always been ghosted on TV2, so i never expected it to work. So, yes, I can verify that moving content to the external drive will render it unaccessible to TV2 unless you transfer it back to the internal HDD.Can anyone confirm that the USB drive is not accessible from TV2? And if not, any info on if it eventually will be?
I think it only asks for permission to reformat if you had content on your drive. Did anyone have it reformat a new drive?
I would think that it does not need to be protected since the 622 can,t record to the ext drive directly yet , and if the ext drive get's close to being filled it won't let you overwrite, sort of like when you try to transfer too much to your pocket dish. "just a guess"I recorded a few short clips just to play around with the options. Transfer both ways and play back from USB works without problems. One issue I found is with Protected recordings. When you transfer a Protected program to USB you no longer see the protected logo when it's on the USB. And it is no longer protected as you can delete it without the code. But if you transfer it back to the 622 the protected symbol comes back and it is sill Protected.
That's why I only dumped Oprah and some other unwanted shows out to archive. Offhand, I hope this is corrected in a future release because I would love to have one HDD full of the kids HD recordings (Cars, Monster House, Chicken Little, Corpse Bride, Toy Store, The Nightmare Before Christmas, etc.) that I can tote around to multiple 622s.Be very careful with that. They said on Tech Chat that it can ONLY be switched to a different receiver THREE times. After the third time, it locks to whatever receiver it is on.
I haven't tried copying the receiver 1 show to receiver 2. If that works, I could probably off-load all of the shows, format the drive fat32/ntfs, then let one of the receivers reformat the drive to get my 3 connection count back. This would at least be a good trick for moving shows between receivers, as long as the format back to fat32/ntfs is done periodically to clear the managing receiver count on the drive.
oops I don't have that problem since my wife and kids have their own systems, but i have also noticed that I can delete locked events "before the update" without putting in my code if my system is not lockedMy issue is recordings accidentally getting deleted by the wife or kids (or me if I fat finger a couple commands). If they are watching off the external drive I no longer have that extra level of security.
Well that sucks! So even if you have two 622's on your account you're stuck to using it on one after 2 switches? One of the main reasons for using this for me was to enable me to watch stuff in the bedroom that I recorded in the living room and vice versa. WTF!
Something to note, if you have a power failure, will the external drive power up when the power is returned, or will it need physical intervention like pressing a button to power it up?
The swapping of drives is not has easy as I'd like, or thought. It requires a reboot from what I've found. I transferred a few programs to external drive #1. Then unplugged it and plugged in drive #2, which was previously formatted by the 622. It said "unrecognized device". I rebooted the 622 and then was able to manage it and move programs. Unplugged this drive and went back to drive #1 and got the same issue. Needed to reboot before it would recognized the drive. Luckily it did and my programs were still there.
Is there a way now to physically drop your recordings on to a media center pc via USB, and then network that througout your house?
