You *could* use the yellow/white/red cables as component cables, just make sure to match them on both ends. I've done it before in a pinch when a true component cable wasn't available. If they're good enough quality the only difference will be the colors of the plugs.
Heh, it's only $4.50.... buy it and you tell us if it's any good. You've got a Monster Cable on hand to directly compare it against. That said, I believe you will REGRET buying it ..... buying the Monster Cable, that is.For the HDMI cable that I am using on my Surround Sound DVD Upconverter, I bought a Monster HDMI cable from Best Buy that was around $70. Will the quality on the cheaper one above suffice?
It will work fine, even on a long-term basis. Tell us, what will be "wrong" ??we here at satelliteguys do not condone such advice, j/k pepper you are right, but def only as a TEMP soloution
If you choose to use the yellow/red/white as a component cable, don't use that as a permanent solution. The impedence of a video cable vs. an audio cable is different (video cables are 75 ohms) I would definitely go for the cheaper HDMI, the only difference you will see is in your wallet.
I have the 56" version of your set. 1080i on the 622 looks a tad sharper to my eyes.
I think that it is best when one device is making conversions, rather than two devices.
Also, I have to think that ESPN, ABC and FOX have to look better when the 720p is not converted to 1080i and then back to 720p again.
Is that an explanation ?? How are they "far superior" ??well Hall I am glad you asked, HDMI cables are far superior to composite, and are, in the opinon of many superior to Component cables (or composite cables turned into component)
hall is right here. As long as you aren't talking about a long run and the composite cable isn't really low grade then it should be fine.
HAll instead of picking fights please read what the OP was saying, he could not tell if he was getting a HD signal, and mentioned he was using the standard cables (which could mean composite).....I then mentioned he was NOT getting a hD signal if he has composite cables (used in composite outputs) can not pass a hd signal...if you go back to my quote you will even notice I put yellow red and white with a question mark asking him.He then mentioned that he was going to get a HDMI cable as he had a extra HDMI slot, someone then mentioned that he could put his composite cable in the component cable slot and add a audio cable and he will be fine for a temp setup, I then quoted him and said we at satelliteguys do not condone this behavior, but it will be fine for a TEMP soloution, then asked him when he got his HDMI cable to use it-meaning dont stick with composite cables in the component slot, use that HDMI cable as it is the best connection he can get and IMO looks cleaner. Never ONCE did I say composite cables will not work as compnents. I have tried them and they do work. In the End he did have component cables and is getting a HDMI for $4 bucks (a pretty good price.) and again NEVER ONCE DID I SAY YOU CANT USE COMPOSITE CABLES. only HDHEAD said that, so why would I have to put scientific fact about why it wont work when I know it does? and why am I repeating myself? I didnt I just put the order of connections which is better then which, you are just taking it the wrong way. so instead of picking a fight and not reading what people wrote, actually take your time and read what they wrote, it helps out in the end, dosent make you seem like such a meany![]()
