1000+ problems
How are you insuring you are aiming with the 119 LNBF?
I use a meter with a 22KHz signal generator.
canot detect 119 signal or 110 signal with the proper lnbs i can only detect 110 signal with a 119 lnb please help
I just installed a new 1000+ and noticed the switch wiring for the 110 and 119 was different on the switch instructions. I swapped the 2 cables and solved my problems. Try switching the cables at the switch for the 110 and 119, It says you can swap these either way but it made a difference on my install and only worked 1 way
Indy Locals Now Spotbeam
Need some advice...
