110 Signal Lost on One Receiver
mdonnelly
8,183
2,979
Mustang, OK
I have 2 311 receivers, and 2 811 receivers. 3 of the 4 get both 110 and 119 from the Dish 500. One 311 has stopped seeing the 110. I did the standard troubleshooting, disconnecting the sat cable and running check switch, doing the reset to factory defaults, but still it only sees the 119.
The LNB is a DP Quad. Is this a LNB problem, a Dish 500 problem or could it be a receiver or cable problem. One thing I did notice now is that the cable coming out of the grounding block for that box is not as thick as the other 3 cables. I think the installer used some of the old cable TV coax.
Any thoughts? Thanks.
Mike D.
I moved the receiver to a location with a working 311. After a check switch, this one worked there too. When I moved it back, the same symptoms came back. I'll work on the outside cables tomorrow.
Edit: Turns out that two receivers don't pass the switch test. One gets the 110 channels, the other gets the 119 channels. I'm thinking new DP Quad at this point.
newby needs some advice / receiver / tv
Use a Samsung SIR-T451 as HD Backup during Rain Fade
