111 Receiver and 1000.4 Dish-No signal
The receiver will get a signal in Point Dish but since it can't decode the MPEG4 then no channels will be received.
If it only gets MPEG2 the signal meter probably wont work on 72, 77 or most of 61.5
You will need to switch to a 1000.2 (or western arc) dish
No, it can pick up the signal on Point Dish just fine as it is still capable of 8PSK. MPEG4 vs MPEG2 is just a difference in the data stream, not the actual signal itself.
Also there is the option of the WA LNB for the 1000.4.
But the real question is: How did OP end up in this situation? More info is needed.
May have to switch back to Dish immediately. Directv sucks.
EXT HD and RECIEVER SWAP
