2/3/2011 12:16pm - Uplink Activity Report - 47 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/3/2011 12:16pm - 47 changes
Uplink Comparison Range: 02/03/2011 12:00P - 02/03/2011 12:16P
Channel Removals:
5873 - FUSE (NA) [MPEG2 SD] removed from EchoStar14 119W TP 10 ConUS beam (Fuse)
5873 - FUSE (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 05 ConUS beam (Fuse)
Channel Moves:
5190 - KATV [MPEG4 HD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Little Rock, AR-ABC) (A) (H)
5191 - KTHV [MPEG4 HD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Little Rock, AR-CBS) (A) (H)
5192 - KARK [MPEG4 HD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Little Rock, AR-NBC) (A) (H)
5193 - KLRT [MPEG4 HD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Little Rock, AR-FOX) (A) (H)
9354 - KARZ [MPEG4 SD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Little Rock, AR-MNT) (A) (H)
9355 - KASN [MPEG4 SD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Pine Bluff, AR-CW) (A) (H)
9357 - KVTN [MPEG4 SD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Little Rock, AR-Pine Bluff, AR-REL) (A) (H)
9358 - KKYK [MPEG4 SD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Camden, AR-IND) (A) (H)
9359 - KETS [MPEG4 SD] moved from Nimiq5 72.7W TP 16 ConUS beam to EchoStar8 77W TP 16 ConUS beam (Mkt:Little Rock, AR-Little Rock, AR-PBS) (A) (H)
9055 - WAWSD [MPEG4 SD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Jacksonville, FL-Jacksonville, FL-MY) (A) (H)
5150 - WTVQ [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Mkt:Lexington, KY-Lexington, KY-ABC) (A) (H)
5151 - WKYT [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Mkt:Lexington, KY-Lexington, KY-CBS) (A) (H)
5152 - WLEX [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Mkt:Lexington, KY-Lexington, KY-NBC) (A) (H)
5153 - WDKY [MPEG4 HD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Mkt:Lexington, KY-Danville, KY-FOX) (A) (H)
9211 - WKLE [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Lexington, KY-Lexington, KY-PBS) (A) (H)
9212 - WLJC [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Mkt:Lexington, KY-Beattyville, KY-REL) (A) (H)
5170 - WHAS [MPEG4 HD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-ABC) (A) (H)
5171 - WLKY [MPEG4 HD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-CBS) (A) (H)
5172 - WAVE [MPEG4 HD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-NBC) (A) (H)
5173 - WDRB [MPEG4 HD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-FOX) (A) (H)
9099 - WBKI [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Campbellsville, KY-CW) (A) (H)
9100 - WMYO [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Salem, IN-MY) (A) (H)
9101 - WKPC [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-PBS) (A) (H)
9102 - WKMJ [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Louisville, KY-Louisville, KY-PBS) (A) (H)
5154 - WKPD [MPEG4 HD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Paducah, KY-Paducah, KY-PBS) (NA)
9261 - WKPD [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Paducah, KY-Paducah, KY-PBS) (A) (H)
9263 - WQWQ [MPEG4 SD] moved from Nimiq5 72.7W TP 12 ConUS beam to EchoStar8 77W TP 12 ConUS beam (Mkt:Paducah, KY) (A) (H)
5200 - KSPR [MPEG4 HD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Springfield, MO-ABC) (A) (H)
5201 - KOLR [MPEG4 HD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Springfield, MO-CBS) (A) (H)
5202 - KYTV [MPEG4 HD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Springfield, MO-NBC) (A) (H)
5203 - KSFX [MPEG4 HD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Springfield, MO-FOX) (A) (H)
7224 - KRBK [MPEG4 SD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Osage Beach, MO-N/A) (A) (H)
7225 - KCZ [MPEG4 SD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Springfield, MO-CW) (A) (H)
7226 - KOZK [MPEG4 SD] moved from Nimiq5 72.7W TP 18 ConUS beam to EchoStar8 77W TP 10 ConUS beam (Mkt:Springfield, MO-Springfield, MO-PBS) (A) (H)
7325 - WPBO [MPEG4 SD] moved from EchoStar15 61.5W TP 26 ConUS beam to EchoStar8 77W TP 14 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-PBS) (A) (H)
6809 - UP4 [SD TV] moved from EchoStar8 77W TP 10 ConUS beam to Nimiq5 72.7W TP 18 ConUS beam (Virtual Channel) (NA)
6821 - UP5 [MPEG4 HD] moved from EchoStar8 77W TP 16 ConUS beam to Nimiq5 72.7W TP 16 ConUS beam (Virtual Channel) (NA)
6822 - UP5 [MPEG4 HD] moved from EchoStar8 77W TP 14 ConUS beam to EchoStar15 61.5W TP 26 ConUS beam (Virtual Channel) (NA)
6848 - UP11 [MPEG4 HD] moved from EchoStar8 77W TP 12 ConUS beam to Nimiq5 72.7W TP 12 ConUS beam (Virtual Channel) (NA)
Channel Package Flag Changes:
5280(16) - WGXAD [MPEG4 HD] - EchoStar8 77W TP 13 ConUS beam changed to Available (H) (Mkt:Macon, GA-Macon, GA-N/A)
5283(24) - WGXA [MPEG4 HD] - EchoStar8 77W TP 13 ConUS beam changed to Available (H) (Mkt:Macon, GA-Macon, GA-FOX)
Transponder Changes:
Nimiq5 72.7W TP 12 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 16 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 18 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
EchoStar15 61.5W TP 26 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
Channels in the system: 7456
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
E1 only does the odd, E4 has been in an inclined orbit to save the remaining fuel on board, so perhaps they had to use some fuel to bring E4 in to replace E8.
I believe Dish has to be using E-8 because there was only a small number of TPs that still worked on E-4 and the ones listed are not the ones that worked on E-4. Now it is possible that when the stuck solar array deployed a few years back that some of the TPs became active but my guess would be that did not occur.
