211 USB Hub
  • Thread starter Thread starter Joe99
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
Joe99
97
Massachusetts
For those of you who use a Hub with a 211, a few questions:
First though, some info. I now have an EHD attached to my 211 and it works fine. It works so well that I now have about 3 hours of HD space left.
How do you first setup the Hub? Do you use the Dish software to disconnect the current EHD, or just power it down?
Once set up, is it enough to power down the EHD that is in use and then power up the next one, or is there a more complicated procedure that is required? Some sequence for instance?
Need the Hub be powered also or just the drives?
A non-Hub question: what is the largest drive that can be used with the 211? I have seen posts that the 722 can now used a 2TB drive, but I am not sure about the 211.
Thanks for any help.
922 replaced
Force guide reload
