3/5/2013 1:17am - Uplink Activity Report - 30 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 3/5/2013 1:17am - 30 changes
Uplink Comparison Range: 03/05/2013 01:01A - 03/05/2013 01:16A
Channel Additions:
6385(38) - KMCI [MPEG4 HD] added to Ciel-2 129W TP 04 Spotbeam 29 (Mkt:Kansas City, MO-Lawrence, KS-IND) (A) (H)
6385(38) - KMCI [MPEG4 HD] added to Unknown TID#1480 (Mkt:Kansas City, MO-Lawrence, KS-IND) (A) (H)
6366(4) - WACP [MPEG4 HD] added to Echostar12 61.5W TP 01 Spotbeam 5 (Mkt:Philadelphia, PA) (A) (H)
6841 - UP29 [MPEG4 HD] added to Unknown TID#1418 (Virtual Channel) (NA)
6841 - UP29 [MPEG4 HD] added to Unknown TID#1499 (Virtual Channel) (NA)
Channel Removals:
8437 - KMCI (A) (H) [MPEG4 SD] removed from Unknown TID#1480 (Mkt:Kansas City, MO-Lawrence, KS-IND)
8160 - WACP (A) (H) [MPEG4 SD] removed from Unknown TID#1573 (Mkt:Philadelphia, PA)
6852 - UP9 (NA) [MPEG4 HD] removed from EchoStar15 61.5W TP 08 ConUS beam (Virtual Channel)
6852 - UP9 (NA) [MPEG4 HD] removed from Echostar15 61.5W TP 11 ConUS beam (Virtual Channel)
Channel Moves:
5180 - WPBF [MPEG4 HD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Tequesta, FL-ABC) (A) (H)
5181 - WPEC [MPEG4 HD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-West Palm Beach, FL-CBS) (A) (H)
5182 - WPTV [MPEG4 HD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-West Palm Beach, FL-NBC) (A) (H)
5183 - WFLX [MPEG4 HD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-West Palm Beach, FL-FOX) (A) (H)
5184 - WXEL [MPEG4 HD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-West Palm Beach, FL-PBS) (A) (H)
5185 - WTVX [MPEG4 HD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Fort Pierce, FL-MY) (A) (H)
8867 - WFGC [MPEG4 SD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Palm Beach, FL-IND) (A) (H)
8868 - WWHB [MPEG4 SD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Stuart, FL-N/A) (A) (H)
8871 - WPXP [MPEG4 SD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Lake Worth, FL-ION) (A) (H)
8873 - WFUN [MPEG4 SD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL) (A) (H)
8875 - WTCE [MPEG4 SD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Fort Pierce, FL-TRIN) (A) (H)
8876 - WBEC [MPEG4 SD] moved from Unknown TID#1418 to EchoStar15 61.5W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Boca Raton, FL-EDU) (A) (H)
5170 - WZZM [MPEG4 HD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Grand Rapids, MI-ABC) (A) (H)
5171 - WWMT [MPEG4 HD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Kalamazoo, MI-CBS) (A) (H)
5172 - WOOD [MPEG4 HD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Grand Rapids, MI-NBC) (A) (H)
5173 - WXMI [MPEG4 HD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Grand Rapids, MI-FOX) (A) (H)
5174 - WOTV [MPEG4 HD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Battle Creek, MI-ABC) (A) (H)
5175 - WGVU [MPEG4 HD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Grand Rapids, MI-PBS) (A) (H)
8714 - WWMTD [MPEG4 SD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Kalamazoo, MI-CW) (A) (H)
8717 - WLLA [MPEG4 SD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Kalamazoo, MI-IND) (A) (H)
8720 - WTLJ [MPEG4 SD] moved from Unknown TID#1499 to Echostar15 61.5W TP 11 ConUS beam (Mkt:Grand Rapids, MI-Muskegon, MI-N/A) (A) (H)
Channels in the system: 8713
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated
It COULD be a recycled TID# on E16, but the uplink report thinks it's an E15 TID.
FYI:
TID#1480 is TP20, SP63
TID#1418 is TP18, SP57
TID#1499 is TP19, SP54
TID#1573 is TP23, SP3
:D
Odd, if those are the right beams, they should have no trouble covering the respective DMAs. Even if the power was a little low, each market is well inside the beam. I also thing at least one person would be complaining they lost locals when they switched.
Currently the Grand Rapids MI beam has no signal on the respective Transponder I am north of it but have been able to see it in the past
Leave it on TP19 for a few minutes at least. I have seen the new satellite take forever to get a lock.
Maybe they moved them to CONUS because they want to change where they are uplinked from. Perhaps they move to CONUS, do their rerouting and then put them back on spot beam.
The new beams are tighter, so you may be out of luck.
Nevermind, I didn't notice, did you try TP11? If the uplink report is accurate, then they moved to CONUS TP11
Talked to someone living in Grand Rapids Mi transponder 19 spot is at 9 percent It use to be at 70 Sounds like signal issues
Or they could have just powered it down.
I'd think if it was an issue, we'd see at least one customer on this or the other site complaining of getting locals knocked out. Perhaps you might ask them if locals had been going out before the move.
KMSP in Mpls St. Paul was out this morning. Screen said something like "no need to call Dish is aware of the problem"
That screen typically comes when you are trying to get a SPOT and are out of it. I got it when they moved PITTS to Spot and I lost my conus SPOT ironically.
Comes up anytime you lose signal on a local. I've got it when the channel was actually down (i.e. the transmitter was out where Dish gets programming), during rain fade events locally, and during rain fade events at the uplink center that delivers my locals. Could also come from spot issues. Your receiver is just programmed to say that for locals whenever the signal lost screen would normally come up. They are just trying to prevent calls.
D
3/12/2013 3:47pm - Uplink Activity Report - 14 changes
D
3/13/2013 4:02pm - Uplink Activity Report - 66 changes
