301 in Ohio?
catman60
SatelliteGuys Guru
132
michigan
a friend of mine from Ohio called dish to see if he could add a 301 to his account. he has 2 dual tuner receivers now. they said it wouldn't work.is it because the 301 doesn't work in Ohio or would it be because he would need a dp 44 switch or something of that nature to handle the 3rd receiver
there are only a couple markets where 8PSK is used for locals...none in Ohio
If he is on a Eastern Arc they wont add the 301 because it isnt MPEG4. You can only have MPEG4 receivers on an EA setup
Two issues. 1 - What switch/lnbs does he already have? 2 - How long ago did he set up service?
New installs are all set for MPEG-4 only. So the system might not allow them to add it.
i don't think he has any switches.dish pro twin lnb with one cable comming from 110 and 119 into his two dual tuner receivers.his system is about 4 years old. would need a switch ,44 or something in order to get the 3 rd receiver hooked up.not enough outputs?
If 2 dual-tuner receivers are connected, it's probably a DP Plus Twin. Some options to price out:
1) replace the DPP Twin with a DP Twin, add a DPP33
2) add a DPP44 (some installers recommend not using a DPP Twin here)
3) for SD receivers, replace the dish with a Dish 1000.2
4) for HD receivers, replace the dish with a Dish 1000.4
AMC HD?
ESSENTIALS PACKAGE
