508 & 721 on dpp & dp lnb's?
oldanbo
59
Sequim, WA.
I currently have a 622 hooked up to two sat dishes. I believe 110 & 119 are on the dish with the dish pro plus lnbs and that 129 is on the dish with the dish pro lnb.
My sys info screen shows the following:
H: Device:dpptwin, twin(1), twin(2), dual(3)
I don't know what switch was used because it's somewhere in the attic.
Here is my question. I own a 508 and 721 and want to connect one in a separate room. Will either of these receivers work? I am led to believe that the 721 is dpp compatible but that Dish no longer supports the 721. I was told elsewhere that the 508 is still supported, but, that it will not work with the dish pro plus gear.
I appreciate any help on clarification of this info. I just don't trust csr roulette.
Thanks in advance,
Dan :confused:
Your switch is actually inside the LNB housing. No worries; either of those receivers (and even a legacy receiver) can be hooked up to a DPP twin.
"Dish no longer supports the 721" is not your case, since you used it under your existing account - just reactivate it and you good to go with it.
Thank you
for your responses.
I left dish for 6 months(or so) with my 508 and 721 so they gave me a new account number when I came back for the 622.
I guess I'll look at the 522 or 625 option. :hungry:
Thanks again.
INCORRECT !
Dish deactived all 721 some months ago, Dish will not reactive for you, but they may replace it with a 522 or 625 at no charge.
False statement !
Just search and ask here - how many ppl still using it and recently reactivated on their accounts.
update
I hooked up the 721, it took a software download sometime during the re-boot.
I called Dish, had it activated and it works.
I still don't understand the $5.00 monthly charge in addition to the 5.98 for the 622, since I own the 721, but I'll worry (maybe) about that later.
But, for now the 721 is working again.
Thanks again everyone.
The $5.00 monthly charge is the "Punishment Fee" for buying your equipment thereby avoiding the "Lease Fee" :D
ooops!
Looks like I need to find some crow seasoning. :hungry:
I jumped the gun. The 721 worked fine if I only wanted to watch channel 101. I spent too many hours on the phone with Dish and still could not see any of my subscribed channels including locals.
So....Dish is sending me a 522 under my DHPP.
I'm a little pi__ed about my 721 not working properly, but I guess it's my own fault.
Thanks again to everyone for all of your polite help. BTW, Dish reps were also very patient.
Dan :o
Wait a sec. If you're willing to post requesting snapshots, we could troubleshoot it better then Dish CSR !
the troubleshoot part, I get, the post requesting snapshots part I don't. :confused:
Sorry 'bout that, it's been a really long afternoon. Must have been my getting stuck trying to make it up my snow covered driveway right after I told my wife "now take notes, this is how it's done". WRONG!!! At least she laughed.
:o
pics
Thanks, I will try to post pics.
PICT0001.JPG guide shows locals missing 4,5,7,9,13 etc. all sub'ed too.
PICT0002.JPG system id info
PICT0003.JPG signal strength
PICT0004.JPG switch matrix
PICT0005.JPG guide missing 110,111,112 and other sub'ed channels
When I try to select a channel listed in the guide, I only get a blank screen, except channel 101.
Thanks again, gotta go nite nite now.
It's a card - too old revision '305'. Should be higher around 308 or 30A ( hope some lucky owners of working 721 will shime here with proper revision number). I would pressurize Dish to send you new one ( perhaps DNASP260 ).
MLB TV/Internet
Switch for 129?
