522 problem
cousineddie
30
SW Wisconsin
Got home tonite and could'nt get my locals, had most of the other channels. Did a quick check switch and the 522 sat. tuner one had my 3 sats 110,119.129 but sat. tuner 2 only showed 110. Went to my 211 and 311 and did check switch and everything was fine with them. I have a DPP44 switch feeding them all. Is my switch going bad or is it the 522 or something else. Any ideas?
Is it possible for only the 110 sat. to show up on the check switch and not the other 2 sats if the cable or conn. is bad?
swap the cable from sat in1 and sat in 2 on the back of the rcvr run the test again see if it follows the cable or stays on port two.
Also you dont have a seperator correct?
Dead 721, easiest way to get new unit?
Another VIP722 USB question
