522 question
cruiser83
SatelliteGuys Guru
135
47
Hi, Recently upgraded to a DVR522 dual receiver, running TV1 and TV2.
Pretty basic question here. I want to move our entertainment unit which means I need to unplug the power and disconnect the coax feeds on the back of the 522 unit. If I do that, will I need to do any type of check switch process when I hook it back up, or will it boot up and be good to go? Should I unplug the power before disconnecting the coax's? Does it matter which order you do it in?
Thanks in advance.
as long as you're plugging it back to the same thing it was unplugged from, you'll be fine.
it is safest to remove power first.
