6 Hoppers?
Does Dish still have a limit on how many tuners you can have on 1 account?
I don't know if it's so or not, but a Dish CSR told me one time that 5 hoppers was the limit. Like I said I don't know if that is true.
Why would you need 6 hoppers on one account ,unless you are charging for your own mini cable company to renters on your property.
I too remember 3 cascaded DPP44's being OK. So, that means you've got 12 DPP outputs, which could in principle go to 8 Hoppers without even adding dual DP LNBs to feed two sets of 3 DPP44s.
Mmmmm . . . the CSR I just talked with said 2 Hoppers is the max.
I wonder how many different answers we can get.
Did you mention they would be purchased? 2 hoppers is max for leased.
Glad you mentioned this . . .
I tried calling again and was given this #: 800-333-3474.
The person I talked with said DISH "usually" stops at 16 receivers!
I asked the rep to please check this . . . she came back with 2 leased + 5 purchased Hoppers for a total of 7.
I'll bet 8 wouldn't be a problem.
Reactions: TheKrell
8 would likely be more than the 3 DPP44 could handle, but even outside that, that would be the first install to be audited. And likely audited multiple times... Just some words of advice.
Reactions: navychop
I'm sure that there are MOCA limitations as well.
MoCA is limited to 16 total terminal devices per segment. It should be possible to patch MoCA segments together with wired Ethernet.
Kind of funny that when the CSR told him 7 was max, he wanted to come up with 8, but just for technical reasons. Cool your jets, just kidding:biggrin.
It's interesting you brought up the 44 switches. What's possible and what the manual says are very different. The manual says 3. The apartment buildings I go into sometimes say 12, or 15, or 20. :/
When is team Summit?
Can Joey be Used with Dish 211K Receiver?
