622 receiver optical out;put mototboats.
dspang
Ohio
When I connect the optical output of my 622 to my D to A converter the sound motorboats. And there is no audio signal. I have checked the D to A converter and it works fine but not with the optical output of the 622. Is there a cure?
I have a 722 w/optical output going to a decode-everything Sony headphone adapter. Works great. Either there is something wrong with the optical output of your 622 OR you have a DAC that won't decode the signal the receiver is putting out. Can it handle Dolby Digital or PCM at 48kHz?
optical output of 622 motorboats
The DishNet guy came out today and said I needed to upgrade to a 722. It is more reliable and newer. My DAC will handle Dolby or PCM at 48kHz. I hope that solves the problem. If not I have another way---I have a splitter that takes a HDMI input and splits out optical and analog sound. That works. But then I will need a HDMI spliter. Expensive. Thanks
You can get a powered HDMI splitter from monoprice.com for $23.49. "Mini HDMI Splitter" Part # 8204.
Yer welcome.
Ed
