72 west Wierd Problem.
bobsav2001
155
13
St rémi Québec Canada
Hi Guys.
I have a fortecstar 36" dish on 72 W wich is my highest sat in the sky NO motor no switch clear sky nothing in the way.
The signal is ok the quality keeps jumping from zero to 85.
Moove the dish manualy to 91 W 95 W 103 W 30 W all sig and quality are ok.
Back to 72 W same issue jumping 0 to 85.
Any of you have that issue?
Thanks Bob....
My pansat 3500 will do that if you're aimed close, but not right on. What receiver you using?
Check cables, connectors first, then the aim/skew of the lnbf. Is this happening on all channels on 72w or only on one polarity? Sometimes these intermittent troubles can be a trick to solve, check everything, even with another receiver if you have one.
Lke i said in my post i have checked all that had to be checked coax wires changed lnb and all.
I am a radio tv tech and ham radio operator!!!! and mooved the dish to other sats all works ok
exept 72 WE.
Why all sats would be ok exept 72 W??????????
What transponder(s) are you having issues with?
