721 "guide" button not working
JonUrban
578
Eastern Connecticut
Very strange problem.
My 721 does not respond to pressing the GUIDE button. If I press MENU then get to the guide from there, it will work!?
Sometimes once I go through the above sequence, the guide button will begin to work again for a while.
It's not the remote, as it does the same thing with multiple remotes. If I reboot the 721, the guide button will work again for a while, but after some time it stops again.
Anyone else see this? Is there a remedy?
THANKS
:-jon
921
721
I think there is a memory leak or some such, and the way to fix it is a reboot of the box.
I've seen it when I've used the remote a lot.
Thanks guys. I'll try an "unplug the thing" reboot. It's not the batteries, not only have I changed them, but it happens with multiple remotes.
I too thought the GUIDE button might be worn out (it does get a lot of use), but when I do a "pull the card" reboot, the guide button works for a few days.
Very odd.
Any word on the when we can add a usb harddrive to the 942?????
should i get HOME PROTECTION PLAN??
