I'm going to try to explain the issue I'm having as best I can. When watching a recorded program on the 722 DVR, if you hit the forward button once, that puts you in fast forward at 4x mode. The picture in that motion I believe to be correct, in other words, moving at 4x speed. The problem is, the timer at the bottom is not coinciding with the picture. The timer is clicking off about 35 seconds per change and that is alot faster than 4x. The timer will continue to count off at this rate, then stop, and wait for the picture to catch back up to it. If in the process, you push play, it will resume play where the timer is at the bottom, not where the picture is at. I have software version 511, have swapped receivers once already from Dish, got the second one, and it is doing the same thing. Any one else having this trouble? Any help would be appreciated.
