722 loses signal way too often.
I
inazsully
Thread Starter
899
56
Sun City West, AZ
My 722 (3 years old) loses it's signal and I get the message to unlpug for 10 seconds and reboot it. Now this always works and I can still watch OTA but this happens way too often (every 2 weeks or so) and naturally right at the worst possible moment. I have no obstructions and the wiring connections are tight. Does anybody else have this problem? I haven't called to have it checked but that may be my only option.
coinmaster32
coinmaster32
916
14
USA
If it happens every 2 weeks, it sounds to me like a faulty receiver.
UTMTech
UTMTech
541
Dish tech here, check your signal strength. Should be over 60 on transponder 19 Sat 119. (Menu,6,1,1)
dwarren2
dwarren2
4,076
287
Rochester, NY Region
Are you getting the Partial or Complete Signal Loss screen? If so, try this when you get the screen. Press Guide then Cancel. See if that brings the picture back. If it does, try rewind back and see if you really lost the signal. If this is the case, join the boat. This started happening after a software update earlier this year. Several threads about it.
3HaloODST
3HaloODST
6,648
97
Earth
Speaking of OTA... Are any of your OTA channels weak? I've read, and witnessed myself, that if you tune into a weak OTA station, then switch to a sat station, every time the OTA channel loses signal the sat will get "partial signal loss." Switching to an OTA station that doesn't go out then back to sat fixes that.
I
inazsully
Thread Starter
899
56
Sun City West, AZ
Signal strength on 19 and 119 is 75. Local signal strength is above 90. Error message reads "complete signal loss".
P
pjsjeep
SatelliteGuys Guru
135
33
Tuscaloosa AL
I too have the problem...my 722 is 3 1/2 years old. I do not have OTA. Will check signal strength but doubt its that.
G
gblaue
45
16
Massachusetts
Mine would do the same thing. I'd be watching my 722 downstairs and my wife would be watching the 211 upstairs, my picture would go out and hers would be fine. It would do it all the time. I just had me receiver replaced and it seems better, so far.
I
inazsully
Thread Starter
899
56
Sun City West, AZ
Why would a Dish tech ask me to check signal strength, which I did, and still not have responded after 6 days? So UTMTech, do you have any suggestions that I can try or would you consider the problem to be beyond a simple fix? Have you seen this problem before? If I call Dish and explain the problem will they send out a tech or will they recognize the symptoms as terminal and just send a replacement DVR? Thank you for any advice.
TheKrell
TheKrell
A mighty and noble race originating on Altair IV.
32,471
27,380
Fairfax, VA
UTMTech probably had to go do real work and didn't return here (yet) to say anything. IMHO your signal strengths look fine. I think you are looking at a receiver firmware problem, and disk repeaking or receiver replacement is not going to fix it.
Similar threads
J
Replies
5
Views
922
jjohns
J
Cheddar_Head
Replies
Views
1K
hammerdown
hammerdown
F
Replies
5
Views
921
garys
G
D
Replies
5
Views
1K
Mike88
M
