772K EPG only downloading 48 hrs
DataWave
36
11
I have a 722k, and the other day we noticed the guide was only advancing up to 48 hours instead of the standard 9 days. DVR functions still work (record, pause, play, etc). It was also noted that even though a timer is set to NEW its recording all episodes. Tried the reset button, same thing, unplugged cables, did a check switch to wipe out settings, then reattached cables, and redid switch test to force a download, same thing. All 3 sats (110,119,129) for INPUT 1 and 2 are good. Any thoughts?
DW
Sounds like you covered all the would be suggested bases. Contact DIRT...best advice I can give. Good luck!
Could be the beginning of a harddrive failure or maybe an LNB failure even though everything checks ok could be intermittent. Good job of covering most everything you can do, must be a reader of the posts here since 2006! ;)
One other thing, check the signal strengths. Perhaps the signal for the extended guide is low and you're getting the abbreviated guide? Check Sat 119 transponder 18.
I agree with Tampa, it sounds like the hard drive is starting to fail if you are getting a good signal off 119 trans 18. Send me a PM with your account information to get this replaced.
Solved it. Was a bad cable end on one of the 119 cables. Thx for the help everyone. Extended epg is back.
DW
Spot Beam Assistance Needed
Traverse City locals off the air
