8/14/2014 00:06 - Uplink Report - 10 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 8/14/2014 00:06 - 10 Changes
Uplink Comparison Range: 8/13/2014 23:59 - 8/14/2014 00:06 (PST)
Channel Moves:
5290(9) - WTVM [MPEG4 HD] Echostar16 61.5W TP 03 Conus moved to Echostar16 61.5W TP 28 Spotbeam 36 (Mkt: Columbus,GA (GA - ABC))(A)(H)
5291(3) - WRBL [MPEG4 HD] Echostar16 61.5W TP 03 Conus moved to Echostar16 61.5W TP 28 Spotbeam 36 (Mkt: Columbus,GA (GA - CBS))(A)(H)
5292(38) - WLTZ [MPEG4 HD] Echostar16 61.5W TP 03 Conus moved to Echostar16 61.5W TP 28 Spotbeam 36 (Mkt: Columbus,GA (GA - NBC))(A)(H)
5293(54) - WXTX [MPEG4 HD] Echostar16 61.5W TP 03 Conus moved to Echostar16 61.5W TP 28 Spotbeam 36 (Mkt: Columbus,GA (GA - FOX))(A)(H)
5294(28) - WJSP [MPEG4 HD] Echostar16 61.5W TP 03 Conus moved to Echostar16 61.5W TP 26 Spotbeam 36 (Mkt: Columbus,GA (GA-PBS))(A)(H)
5295(49) - WLGA [MPEG4 SD] Echostar16 61.5W TP 03 Conus moved to Echostar16 61.5W TP 28 Spotbeam 36 (Mkt: Columbus,GA (AL-IND))(A)(H)
5744 - IAD13 [ae] Nimiq5 72.7W TP 25 ConUS moved to Nimiq5 72.7W TP 07 ConUS (IAD13)(A)
5744 - IAD13 [DATA] EchoStar11 110W TP 08 ConUS moved to EchoStar11 110W TP 01 ConUS (IAD13)(A)
5767 - IAD10 [ae] Nimiq5 72.7W TP 31 ConUS moved to Nimiq5 72.7W TP 22 ConUS (IAD10)(A)
5776 - IAD7 [DATA] EchoStar11 110W TP 15 ConUS moved to EchoStar14 119W TP 14 ConUS (IAD7)(A)
Transponder Changes:
EchoStar14 119W TP 14 ConUS (20.000 QPSK 7/8) added.
EchoStar11 110W TP 01 ConUS (20.000 QPSK 7/8) added.
Nimiq5 72.7W TP 07 ConUS (21.500 8PSK 2/3) added.
Nimiq5 72.7W TP 22 ConUS (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 26 Spotbeam 36 (21.500 8PSK 3/4) added.
Echostar16 61.5W TP 28 Spotbeam 36 (21.500 8PSK 2/3) added.
Echostar16 61.5W TP 03 Conus (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 08 ConUS (20.000 QPSK 7/8) removed.
EchoStar11 110W TP 15 ConUS (20.000 QPSK 7/8) removed.
Nimiq5 72.7W TP 25 ConUS (21.500 8PSK 2/3) removed.
Nimiq5 72.7W TP 31 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9477
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
Rut roh. Another CONUS local bites the dust. I'm playing russian roulette with mine.
Will be up linked around 6 pm ET likely and will be at 404 (hopper) or 408 (non hopper)
Was hoping to get a slot in the guide with a test pattern on the screen before then so I could at least set a timer to record the first moments of the broadcast.
Reactions: D. Manley
SEC network and Longhorn network have been added to the WatchESPN app. You'll need to update app..
8/13/2014 12:24 - Uplink Report - 28 Changes
8/14/2014 13:54 - Uplink Report - 19 Changes
