811 and dvd recorder hook up ?
M
Mikec35
Thread Starter
Feb 12, 2006
5
I just hooked up a Toshiba D-VR4 dvd/vcr recorder to my 811 receiver. I can watch a disk or tape being played back through my dvd/vcr on the tv, but I cannot record anything from the satellite channels. Any advice on how to hook this thing up. I have audio/video cables run from the output on the 811 to the input on the dvd recorder. I then ran my component video cables out of the dvd recorder to my tv. Any help would be appreciated! Seems like I should be able to watch tv through the dvd recorder as well?
dfergie
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
:welcome to SatelliteGuys...use S-video for best results with of course the audio outs to your appropriate inputs on your Dvd Recorder. The 811 outputs both SD and HD at the same time... check to be sure the component input on your TV is set for 480P
M
Mikec35
Thread Starter
Feb 12, 2006
5
Thanks for the quick reply. I understand that the s-video will give me better picture quality, but will it solve my problem of the recorder not reciveing a signal from the receiver?
dfergie
dfergie
Proud Staff Member
Staff member
HERE TO HELP YOU!
The composite should be giving you a picture, I have a friend who has a combo like yours different brand, hers you have to have in dvd not vcr mode in order for the S-video or the composites to work out of the components...
M
movieMark
Jan 27, 2006
11
Atlanta, GA
Try This
Try running the DVD/VCR into the tv using component cables since they will give you the best picture and a set of cables for the sound. Then attach composite cables to the monitor out on the back of your tv to the input on the back of the DVD/VCR combo.
I have 811 and a dvd/vcr recording combo as well and that set up works for me.
new_to_hdtv
new_to_hdtv
185
not far enough North
How would that affect being able to record from the 811? :confused: It sounds like he just needs to enable the correct input on the DVD recorder to match the outputs from the 811.
M
Mikec35
Thread Starter
Feb 12, 2006
5
Shouldn't you be able to view channels on the satellite through the dvd recorder?
I tried line 1 and 2 inputs. I also tried channels 3 and 4, just like you would do with a vcr. I will try movieMark's suggestion in a little bit... thx for the replies!!
M
Mikec35
Thread Starter
Feb 12, 2006
5
I finally had time to try this again. I have the output from the 811 going to the input on the dvd/vcr recorder and the output from the dvd/vcr recorder going to the tv. Recorder is set to line 1 input and all is good. Now, I can view tv as I am recording.. Is there a way to record 1 channel while watching another, or will I just have to watch the channel I am recording? Thx...
M
Mikec35
Thread Starter
Feb 12, 2006
5
Is there any way to watch one channel and record another with this set up? thx...
Similar threads
R
Replies
15
Views
2K
811Sucks
8
kikenovic
Replies
5
Views
2K
Beeper
Beeper
C
Replies
7
Views
2K
S
N
Replies
Views
911
nuneza
N
Conner Dain
Replies
Views
814
Conner Dain
Conner Dain
