I'm new to Satelliteguys so let me give my perspective on Shaw TV reception from someone living in S. Indiana (about latitude 38.9). I have 4 800 series receivers (so all signals go through a multiswitch) and a 75 cm dish. I recently bought a signal meter, SATLINK WS-6933, but have been unable to measure a meaningful signal with it as the Quality Signal measures 0. Perhaps it's my meter settings or perhaps the incoming satellite signal is too weak. I believe it's the later. In any case, I typically measure the incoming signal by taking a Shaw box and a TV outside positioned next to the dish. If there are no adverse weather conditions, the typical signal level is 60 to 70 and EcbNo is 6.0 to 6.5. All strong enough to give me a decent picture. Below signal level 60, my picture starts fading in and out. On a bad weather day (rain, thunderstorms (not uncommon here), snow, etc.) the signal level typically drops below 60 thus no TV. My cable run for all TVs is about 100 yards from dish to TV and my signal loss seems to be minimal as I'll get similar readings at the dish and at the TV.
So, with that as background, I have 2 questions:
1. To boost the signal level, I'm considering replacing my dish for a larger dish, say 90 cm or 120 cm. I currently have an LNB, Shaw 75E-G1(T000409), so designed specifically to be used with a 75 cm dish. When I noticed my signal level decreasing, about 1 year ago, I replaced the LNB with a brand new one and saw no improvement in the signal level. Would this LNB still work with a larger dish? If so, are there any special adjustments that I would need to make in order to get it working? I know others have larger dishes, as one of the threads mentions someone in Denver with a 2.4m dish so there must be a way to make it work. Any advice on this would be appreciated.
2. To be sure my WS-6933 meter is set correctly, any advice on how to set all of the settings?
Sorry for the long post. Thanks in advance for all input.
