921 Installation Questions
Jason
30
I currently have a PVR 721 and 501 hooked up to a Legacy Quad. I plan to retire the 501 and hook up just the 921 & 721. I will most likely have the 921 before I am able to get a Superdish. Will I be able to run the 921 & 721 using my current setup? Will the 921 function properly or does it require a 2nd dish or a Superdish to operate? I know I will not be able to watch HDTV without the Superdish but will I be able to watch standard definition TV in the meantime with my current setup?
Also, when I eventually get the Superdish will it come with the proper LNB to run a 921 & 721 together or do I have to buy a switch or some other accessory?
Thanks,
Jason
yup a quad has 4 outputs and your 2 recievers (921 and 721) will need a total of 4 runs. :)
So you will be good to go.
The SuperDish will have everything you need!
Thanks Jason for your question!
Questions on 811/921 OTA program guide
Note from RCA on Dish Network TV's
