922 Connected to internet without ethernet cable?
fred416
12
NYC
How come my 922 receiver is connected to the internet without an ethernet connection to the receiver? How can it be connected to my wireless router? Is there a wireless adapter in the 922? If so, how can it connect without my router authentification password?
Thanks for the info.
How do you know it's connected? can you sling to another device, can you order Dish on Demand programming and view it?, do the three "OK's" show green in the Broadband menu?
I don't have a slinglink, the funny thing is that when i go into settings and do a connection with DishComm, it works i get my connection back with no ethernet cable. My question is how come my router is connecting to my receiver with wireless if i don't give it access to?
Don't get me wrong, i don't mind it, but what happens if i get 4 routers connected into my house? What if i live in a appartment building and the neighbour is using the same router as me "same brand"? Isn't that stealing if my 922 connects to an unknown router?
Nope impossible, i'm the only one with dishnetwork.
Can my router be quipped with something similar? it's a Linksys E-3000.
The 922 must be picking up a homeplug device other than a sling product. The 922 does not have a wireless adapter built in so it sounds like that is the case
Sent from my Droid using the SatelliteGuys app
Yes it looks like it's picking another homeplug adapter.
Can you explain how can i receive connection with the homeplug if no cables are connected to my receiver?
Homeplug sends signal between devices using the home or building wiring just like most baby monitors.
The homeplug is connected to someone else's router. Disconnect your modem and rerun the connection test and i bet you'll still have an internet connection.
Isn't that stealing someone elses internet? So your saying, if that's the case, that dish is looking at my neighbours IP? And they are ok with this?
I'm sure the neighbours are happy to pay for my downloads.
Any way to remove the dish comm feature?
No way to disable or turn it off that i know of. I would have to say if you're the only one with dish they are not detecting conflicting IP addresses so the only concern would be with the neighbor and I really don't think you're using as much as you believe you may be.
Did you look at the back of the receiver? Is there a wi-fi adapter plugged into the USB port? If there is you probably latching onto your neighbors internet. With Dish requirements for installers to get connectivity, it's possible he used one and never told you.
navychop said:
Won't cheap surge protectors block Home Plug?
Most cheap ones will allow the connection. The more expensive ones that have better surge protection and more complex circuitry are the ones will block a HomePlug adapter.
Yes that did the trick.
But i am now keeping the Ethernet cable connected, no wore wireless connections. Also, i Just don't want to use somebody's else internet for my personal usage.
Are you now connected to your network?
Sling
Free Showtime Weekend?
