a couple questions before i buy
ynnedibanez
536
58
Greeneville, Tennessee
i need blindscan, dvb-s, s2, 8psk, and 4:2:2 would be a nice bonus, so from what i've read, the dvbworld card is the only one that can do all of these well.
but i've not seen any mention of digicipher2 or dss in any of the specs for this card.
does the dvbworld 2104d not support digicipher2 and dss?
and if not, if i wanted to, is it possible to run 2 different satellite cards in 1 computer, or is that just asking for driver problems?
thanks for any info,
Denny
You've got your facts right. Good research.
Yes you can run more then one no problem. I use a skywalker-1 which does dvb-s, DGII, dss, and turbo-fec alongside a prof 7500 which does dvb-s and dvb-s2.
Sometimes apps aren't writen to handle multiple of the exact same tuner. But most have no problem. And darn near everything will have no problem with multiple different tuners.
Nice thing about USB though is you can easily disconnect and reconnect them if you do encounter some specialized app that you love but has issues with a second tuner.
I'm on the market also to buy a Linux compatible DVB-S / DVB-S2. I'm shooting for DVBWorld 2006 (PCIe) or DVB-S2 CA USB 2104D. However, I'm kind of concerned if the Prof tuners that uses newer chipsets wouldn't be a better option.
I will use this tuner on an HTPC based on Zotac IONITX-L-E motherboard. This mobo has a PCI Express 16X and I think the PCIe 1x will work fine, won't it?
FTA help needed
Coolsat 6000 acting up, shuts down when I try to blind scan ...
