A little help with hooking up
TJ22
72
I just recently got a HD receiver. I currently have a dual tuner 322 installed and working. I want to keep the 322 and add the 811. So currently I have one cable running in from my dishpro 500. I want to take the 2nd output and run it to the hd receiver. PROBLEM: I need that second output to also run in on the same cable the first is on. So can I add some kind of switch or plexer and once inside the house seperate the signal? so 3 tuners 2 outputs on one cable that runs into the house.
Thanks in advance.
Current setup:
Dishpro500 LNB1 -----PVDP2 Diplexer---322 receiver(dual tuner)(living room)
_______________________|
__________________6 way splitter
_________________other rooms
what I want:
Dishpro500 LNB1-
_______________|-something --something---811 HD receiver
Dishpro500 LNB2-________________|
_____________________PVDP2 Diplexer---322
______________________________|
_________________________6 way splitter
__________________________other rooms
(disregard the _ underscores)
POSSIBLE?
THANKS.
322 and 811
You will need to run another cable from the dish to that second receiver no splitters or diplexors will work to connect up 2 receivers on 1 coax cable, the separator that is on the back of the 322 (looks like a splitter) will only work for dual tuner receivers as well.
National Locals
Am I unconfused yet ?
